Q45 Throttle Screw
supraguy31
626
Pembroke, NC
so I Started my car up today after installing my FFIM and Q45 Throttle body. When it started the Idle was really high and took a very long time before it even wanted to Idle down (like 5 minutes or so)
I know that there is an Idle Screw on there somewhere but I havent been able to find it. Does anyone know where the Idle Adjustment Screw is on a Q45 Throttle body.
thanks
Robert
supraguy31
626
Pembroke, NC
Ah, ok so why is it that its Idling up so high at startup and not settling down any at all until roughly 4 to 5 minutes. Im sure there is a way to Adjust something somewhere.
Robert
rayall01
901
Westfield, ma
Cold start injector, perhaps? A Supra is designed to idle around 1400 rpm on cold start, and will do so for a few minutes until it gets warm enough to run normally.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
Are you running coolant through the TB? There is a waxstat on the throttle body that opens the throttle plate until the engine reaches temperature. You need to remove the linkage that attaches to this if you are not running coolant lines and/or you are running the supra ISC valve.
If your throttle plate is open too wide, the ISC valve cannot bring the idle down any further.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
gaboonviper85;1368950 said:
There isn't one....most modern cars use an electronic valve to adjust idle.
Wrong. There certainly is a screw on the Q45 TB that adjusts the opening of the throttle plate.
supraguy31
626
Pembroke, NC
Yes, I am running coolant lines from the ISC to the Throttle body and then back around to the Line under the Lower intake. Since the Stock throttle body was run that was and Im running a ISC I thought it had to be the same. If there is a better way by all means let me know.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
you need to disable/adjust whatever it is that the waxstat pushes on to move the throttle linkage (there is an adjustment screw - it is painted white in this picture). That cylindrical thing parallel to the tb bore is the waxstat - you can follow the coolant lines to it.
keep the coolant lines hooked up, just disable the waxstat operation, and you should be golden.
supraguy31
626
Pembroke, NC
Ok, I got the throttle Adjustment screw. Thanks for that Picture, Now I need to figure out how to Disable the other thing that you are talking about.
Started the car up a little while ago and the Idle at Initial startup jumps up to around 2400rpms and sits there. This is just a reference for you all.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
if i remember correctly, I just cut off the tab that it interferes with or removed the arm all together. I can double check tonight.
i've got a few pictures in my build thread about my TB modification...although I couldn't tell you where they are as photos are blocked at work...should be on the last couple of pages.
supraguy31
626
Pembroke, NC
Page 33 I think of your Build thread has a Q45. I see the Huge Spring Assemble on mind that yours doesnt have right below the Throttle cable linkage.
Would this Picture be the one that you are referring too.....
I will take a Pic of mine as soon as I get home and I will add it to this Post. Let me know what I need to remove to solve this.
Thanks again.
Robert
supraguy31
626
Pembroke, NC
got it.....
I removed the Assembly that Keeps the throttle linkage up and the Idle Dropped instantly. All I need to do not is remove the Small rod that you were talking about.
Thanks alot all, Idle is around 700rpm once the engine has warmed up.
Robert
