Pulls to the right under acceleration, causes?
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
Hey guys, I just got my car aligned because it was pulling bad. The guys at the shop did a good job on the alignment and I watched them do the whole process. I had them put all the alignment specs to factory but with a little bit of negative camber in the rear. Im running eibach springs so not too low.
Anyways the car pulls to the right anytime that you are not coasting or decelerating. So if your cruising, accelerating, going straight up WOT the car pulls to the right. Its not awful but to go straight you have to turn the wheel left a few degrees to counter it. Really annoying to say the least. Has anyone else had a problem like this? If I am coasting in neutral or decelerating it drives straight. I assume a possibility is the rear suspension bushings. They are OEM so I know there old. Wiggling around the rear wheels by hand doesn't have much play, but the force I can push on the wheels vs cruising force driving at 50+mph are two different things. The spherical bushings in the rear have been replaced so it cant be those.
Any input or experiences/solutions of a similar problem are appreciated
Thanks guys
If the rear suspension wasn't fully loaded when the spherical bearings were tightened it could very well be them again...
Jack it up under the rear arm/hub and see if you can wiggle the rear wheel.
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
So the car is on jack stands, so I put the jack under the lateral arm of each wheel and jacked it up to the normal ride height. STill no wiggle in the sphericals, same as it was with the suspension fully sagged. So I guess its not those?
KKZ SupraMan
163
ohio
Maybe minor brake drag from bad caliper or e-brake draging a little if you hit the brakes whille its pulling does it go strait or pull more thats a good way to tell if you have a front caliper sticking just thinking small here
Asterix
Lurker of Power
Vienna, VA
Have you checked your tire pressures? I find if one rear tire is low enough it does this.
Or, the alignment shop got the thrust angle off. Check your alignment report.
rossman3s
19
Northeast PA
I will second this recommendation. My '88 started off with just pulling a little to the right when the caliper was sticking a bit. As it worsened, it caused a bit of a wobble. I couldn't figure it out until I got her home and smelled the hot brakes on the passenger side while the driver's side was normal.
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
3p141592654;2035423 said:
So to clarify, this started after the alignment?
No it pulled to the right before the alignment, but after I put new tires on I went to get the alignment to straighten it out. It drives straight when coasting but on the throttle not so much.
Tire pressures are on spec. I don't have the alignment sheet, they're printer was not working so I took a picture of the alignment machines report but cant find the pic. Ill check the brakes when the rain here clears up.
But if it were alignment off a bit or one tire low pressure wouldn't it pull to the right all the time and not just on acceleration/cruise?
KKZ SupraMan
163
ohio
Check steering colum to ps rack for unnessary play i had a supra lite in the front from acceleration it would pull ended up being the telescope portion of the colum.
Sside
554
Houston
Thanks guys
Yup.. Sounds like they did an awesome job....
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
Not sure how they could do an alignment with the wheels under a load of rolling down the interstate or something like that, so they did a good "static" alignment
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
super51fan;2035731 said:
Something is worn out or broken if the car pulls one way or the other with throttle.
This is what I assume, It would make sense to be a super worn out bushing maybe on the traction arms. I guess I should go poly, considering a rear set is only around $50
atmperformance
757
San jose
there could be many reasons, most likely a worn bushings but i'd like to throw out this idea, do you have a bad shock that's compressing suspension at a different rate?
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
I actually do... My front right shock is leaking and is on its way out. Its still functioning and not fully blown but within short order it will be
