glad someone can atleast somewhat take my back for a change...sorry for the mini rant, its just every post i get flamed.
the first thing i said was he should get lowering springs, THEN i gave him a FREE alternative if he just wants to play around with different heights.
as for cutting springs, i cut straight across the last coil as flat as i can (horizontally), basically making the cut 3-4 inches wide, instead of cutting the coil straight across which would probably make the spring jump out of the perch when fully extended. you can take that a step further and give that last coil some heat to make it flat and a perfect circle again...but on the cars ive done it to, when compressed it lays in the perch pretty nice and flat, heating that last coil is more to adjust the height that tiny bit more. hell, i even had to do it to a set of vogtland lowering springs because they werent level, the front of the car was really noticeable, i thought i put the rears on the front or something...double checked and decided the do the top coil chop and it sat perfect
also i stated it was not a proper way of doing things...but free, yes indeed it will work if youre cheap. im just saying, ive been there...where you have spare time on the car, youre bored with it, but youre also broke. free mods are the best in my opinion.
a simple, "no i disagree" wouldve been more than enough to get your points across.
