Problems to get a MHG
a_sesshoumaru
Suprita
Jan 7, 2007
455
El Salvador
Hi, i ask for help, i blew my head gasket, and where i live i only find OEM,
i want to buy a metal one but non of the stores i have visited on the internet take international credit cards. I think this problem should be solved for at least one of the stores here is supramania. i guess all foreing supra owners have the same problem.
Please help us.:1zhelp:
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
Do you have paypal? You can transfer money from your bank account to paypal, then pay with paypal
empera
Authorized Vendor
Philly.
Where do u want to order it from, im sure something can be done...i send things to nicaragua all the time so there must be a solution to ur problem.
suprarich
Guest
Nov 9, 2005
2,187
ohio
How can you not have paypal, its a web based payment center. If you have a computer, you can have paypal.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
a_sesshoumaru said:
because i upgraded my turbo to 55 trim and i had oem head gasket not metalic
That doesn't mean jack guy, sorry. Unless you were running 500 HP on that stock gasket and the head and block were flat and torqued to spec, then there was no reason for the gasket to blow unless you detonated, then you've probably got more problems than a simp BHG.
Edit: This post from you leads me to believe something you've been doing the entire time is very wrong: http://www.supramania.com/forums/showpost.php?p=605135&postcount=20
tte
Breaking In - in progress
Northern California
Its best you get the block and head deck checked out to see if they need machining and then you can decide what size head gasket thickness you need.
If you blew the head gasket again, that could mean that something was done incorrectly.
Cheers,
Roy
tte is on it...if your block/head is not in TRSM spec for flatness, there's not a head gasket (MHG or stock) that is going to seal properly.
TurboWarrior
Canada
Depends on what he torqued the bolts at, The stockers could have stretched or something. you never know. you're not supposed to reuse them btw. use arps this time around. Check to make sure the block isnt terrible while your at it
