Problem with blowoff valve
1988ma70supra
553
San Antonio, Texas, United States
My car stalls when the rpms are high at about like 2500 or 3000 and i push the clutch to drop the rpms to idle. ive noticed this ever since i changed from my stock intercooler pipes to the cooleeze hardpipe kit. when i did this i also changed from the stock bypass valve to a turbo xs type-hrfl blow off valve. Someone told me that i might have an issue woth the blow off valve that i bought and that i should try a different one. He also said that it could also be my vacuum lines. i have changed out all of my vacuum lines and the problem is still there. Could it be the blow off valve like that guy told me and if it is what blow off valve could i use to take care of this problem? any suggestions.
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
Wrong section =]
These cars run an AFM, so when a ton of air suddenly disappears (via BOV) the motor will run rich and sometimes stall out. If you insist on using a non-recirculated BOV, you need to find one with a diaphragm that can be adjusted or get your car tuned for it.
Ma70.Ent
1,871
NJ
This is the 7MGE section. Your thread has been moved to the appropriate place...
