Probe locations
Boosted Supra
AEM 7MGTE 6765
Apr 7, 2005
353
Valley Stream, New York, United States
I was wondering about probe locations for oil pressure/temperature. Right now I have my probe for my oil temp drilled into the oil drain plug, works fine there. I want to move it somewhere else, I was thinking about the J-tube block off, is that a good place to set both oil pressure/temp probes at? Would it be easier to get an aluminum J-tube block off or use the stock one with drilling and tapping? Thanks
boost PSSH boost
SM's Welding Guru
Apr 4, 2005
465
Marshall, WI
Youll definitely want the oil temp probe in the oil pan, not the j-tube blockoff.
drill and tap the side of the pan towards the bottom.
for oil pressure, use a greddy filter sandwich adapter or T into the stock oil pressure sensor port.
Boosted Supra
AEM 7MGTE 6765
Apr 7, 2005
353
Arnout's location is sweet but I need a place to install two probes, not one. I know about the oil pan, but I don't want to drop the pan just to drill and tap it. I thought the J-tube location would be good, but too far away from the pan, right?
