Prepping turbo for installation?..
FlipSupra8
72
maryland
alright so i finally got the turbo off..i noticed that my stock downpipe has a big crack on the flex part or whatever...which can explain smoke in the engine bay eveyrtime wot happens..its cracked around and is about hanging on 1 inch...how much can this effect performance on the turbo?..the car itself?...lost of torque etx etx?
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,585
Great Lakes State
How much power do you lose from a inter cooler pipe off with a crack in it.
How much fuel leaks out of a tank with a crack in it.
If you had a leak in you oxygen tank while you were you deep sea diving, how much time would you have and would you lose oxygen?
You " are " losing power from this. You also should fix it, I wouldn't want that much heat coming out where yours is.
:: snowart ::
92TealSupra
Sep 2, 2008
1,585
Great Lakes State
IJ.;1300162 said:
A "Downpipe" isn't an Intercooler pipe....... :nono:
I was referring to the Downpipe and Intercooler as a loss of power if they both had holes in them.
I know that you knew what I was talking about.
:boink:
92TealSupra
Sep 2, 2008
1,585
Great Lakes State
IJ.;1300186 said:
No actually I had NFI what relevance "intercooler" had to a cracked downpipe....
Well then, I apologize for trying to explain something and not doing it correctly.
Time to go to bed, have a good day.
:sleep:
Doward
4,245
Alachua, FL
You can just remove the exhaust behind the turbo and have no real loss of power. Intake piping, however, must be properly sealed.
Exhaust that is unsealed won't hurt the engine, but I wouldn't stick around for long like that ;)
jdub
Feb 10, 2006
10,730
Valley of the Sun
These analogies don't float...you are trying to compare apples to oranges.
InFrnt0fU
Lurking Supra Socialite
I love it when you hard headed guys end up extending the thread after the questions have been answered to argue about semantics. This place cracks me up.
For the record, I completely got what his general analogy was saying but definitely saw Ian having a problem with it because it was technically incorrect.
FlipSupra8
72
maryland
okay...i thought i would loose somethign but not as much as he stated..thanks everyone for the correction...anyway i'd just like to thank everyone on this forum because you guys are really helpful..since i got my supra this place has a been a big help to me...i was just wondering...i really dont wanna do it but i read about it...gutting the first cat?...any input on that?..im really against it but i was j/w whats the effects of that
jdub
Feb 10, 2006
10,730
Valley of the Sun
Just to be clear - you will lose very little (if any) power from a hole in the DP that far down from the O2 sensor.
A gutted CAT is illegal - The power gain is minor compared to the fine if caught. Get a high flow CAT.
Doward
4,245
Alachua, FL
I proved that one on the dyno - a gutted cat vs straight pipe was the difference of ~7rwhp on a 290rwhp vehicle.
The gutted cat allows exhaust to suddenly expand and cool, 'plugging' it up ;)
jdub
Feb 10, 2006
10,730
Valley of the Sun
Reduced flow...not "plugging it up" per say. A normal CAT does the same thing, but also has the substrate inside that will impede flow as well. The CAT (even a gutted one) will also help muffle exhaust noise and reduce the "drone" sound a lot of guys experience.
