first off i have a question, they guy at toyota parts said i can still get the engine wire harness so is this what im looking for?
http://www.cygnusx1.net/Supra/Library/EPC/291220/catalog.aspx?F=8202&P=1
looks to be the bottom one
and secondly i have a few things already and if you guys want to chime in a add anything i should also get (im trying to get as much as possible aside from internals beforehand)
what i have so far
1: stone gasket set (will figure out what mhg to get when machining is done)
2: horseshoe gasket from toyota
3: 2 gaskets that go between the timing belt case and the block from toyota
4: new accordion hose from toyota
5: ngk spark plug wires
6: toyota oil pump
7: toyota fan shroud (already put that one for now)
8: apexi intake
9: ddp
10: bic test pipe
11: hks dragger exhaust
12: hopefully getting a new engine wire harness from toyota
13: i replaced the ps pump and water pump about a year ago but i might do that again just for peace of mind
what i have so far
6: toyota oil pump
8: apexi intake
9: ddp
10: bic test pipe
