7MGTE with CT26 running at 11psi. Stock fuel system, 75mm exhaust, cartech intercooler.
I feel (and datalog) a sag in power that start at 3200 rpm and last until 3600 rpm. It is subtle, not a collapse, but just doesn't make as much power. After 3600 rpm power stays solid to redline.
It happens about 0.5 second after the ecu switches open loop, and it happens long after the fuel pump switches to high speed, so I don't think it is due to either of those things.
Has anyone else noticed this. It is defintely more noticeable as the boost is increased. Datalog is attached.
