Well i noticed this a couple nights ago, the knock sensor (according to SAFCII) was registering anywhere from 0-3HZ from the sensor. This only happened at an idle (which is around 9-1.1K). I figured that couldn't be good since its always been zero. Now today i noticed it reading anywhere from 0 to up and over 23Hz! And now the reading stays most of the time throught the RPM from 1-5Hz. Idle more normally now is between 12-18Hz, sometimes it hangs between 1-6Hz at idle, sometimes 0. As soon as i press the accelerator it goes down drastically. Is knock reading normal or just plain bad and just a hint of what may come later? :1zhelp: :1zhelp: :1zhelp:
