So, I rebuilt the engine, put the car all back together, take it off the blocks runs nice - purrs like a kitten - ready for the first test drive.
I go to throw it into reverse to back out of the garage and "grrrrrrind......"
Sooooooo.... My long awaited first drive has turned into possibly more wrench pulling to remove the tranny and flip the clutch disk.
Here's the symptoms:
-Push the clutch in, wont go into gear with car running
-Slave is actuating the fork and pulls the throwout bearing, I can watch the fingers on the pressure plate moving.
-Adjusted the clutch pedal free play (quite a chore) it now pushes the arm so far something starts to grind, still no release.
I can see between the fingers of the pressure plate all the way to the splines and it appears that the longer part of the clutch disk hub faces the transmission. Is this the right direction?
Everything fit together so nice going in...
I have searched and found confusing posts and the TSRM is no help.
This is the stock clutch on 7MGTE
Advise?
T-
Advise?
T-
