pos
87supraturbo19
pearl white
Jan 16, 2006
360
Springfield,MO
well i soon i will be leaving this website. today for the second time i blew my head gasket. i have already started taking it apart, and soon as i fix this pos i am selling it. i swear it is one problem after another with this car. i dont have the money nor the time for this piece. i will never own one again. if i do it will be an n/a. :icon_evil sorry guys i just have to relieve some stress so were else to do it than here.
N
NDBoost
Guest
you probably didnt do it right, dont blame the car blame yourself.
superiorsupra
ceres
I know how you feel, all cars that are a decade and a half old are going to be a pos if you don't take good care of it. I went through two rebuilds with my car, and it's still a pos but I love it to death.
87supraturbo19
pearl white
Jan 16, 2006
360
Springfield,MO
87t,167,000 odometer stopped working, fair condion pearl white front bumper needs repainted.interior seats a little faded other than that pretty nice.the motor has been rebuilt bored .050 over, arp studs,2.25 exaust, new clutch,new fuel pump.
N
NDBoost
Guest
go through the steps you used when doing the HG.
Did you deck the block AND head? did you torque to 85+ft lbs, did you use ARP studs. What kind of gasket did you use. Did you make sure the HG was on straight and properly, did you torque the head down in the proper pattern, did you use any kind of sealing aid (copper spray, permatex). Again what model/brand of HG what was the thickness etc.
details details!
92turbo4life
1,289
wherever
yeah^ honestly for you to get all pissed it isnt worth it... i would be able to put my car up that there was sa small lil thing you forgot and it caused this......
well find out:)
87supraturbo19
pearl white
Jan 16, 2006
360
Springfield,MO
i dont it all. i just got done retorqing my studs a couple of weeks ago. the thing that i think it is. my recent posts about my car over boosting for no reason. my car is pretty much stock but for some reason it would slam my boost past 8 psi and would do it really quick. that cant be good for my hg. but know body could give a definetive anwser why my car was doing this.
N
NDBoost
Guest
check your wastegate vac lines probably not hooked up, got ahole in them or something along those lines.
You probably detonated and blew the HG if its a stock HG.
N
NDBoost
Guest
yeah well thats why your boost is spiking to 8+ is that wastegate, check the lines and check the diaphram. Check the lines again even if you just replaced them.
do you have a MBC (manual boost controller) if so the lines might be on reverse.
92turbo4life
1,289
wherever
i have a aftermarket but all i have is a test pipe and a bov and im running 9psi.. my dads friend also put a new hg on the car when i got it with some injectors and im fine at 9psi
