Ported intake manifold
TRACKMKIII
464
Atlanta,GA
I have already ported my intake manifold, but I don't think my workmanship was very good because I was rushing and it was my first time. so last weekend I decided to go to the junk yard to get anothor manifold and try it again. I thought I would share my progress if anyone wants to follow along. I have been working on the "Y" pipe for about 3 days now and it is turning out really well.
Here are some pictures of the work so far.
Tell me what you guys think. I think it is a good mod because it is FREE!! If you have any information, advice or feedback let me know!!
TRACKMKIII
464
Atlanta,GA
Here is a picture of the basic tools I have been using. It is just a 90 degree die grinder, carbide bit and a 80 grit sand paper roll. I think a straight die grinder would work better so I order one from the Snap-on truck today and I also have a longer carbide bit coming too!!
s383mmber1
3,614
Somers New York
Looks very similar to mine, ill throw up some pics of it too, if i can find some that is!
I went well past the engravings on it! And i left the bumps and all that nonsense, why? Because im sure toyota didn't put t there for the heck of it!
:icon_bigg
I thought id throw a extra up there as well!
TRACKMKIII
464
Atlanta,GA
Wow man that looks good!! I thought about opening the "Y" pipe up to the same size as the throttle body gasket but the throttle body is already the size of the gasket so I didn't think there would be any benefit. Also after you opened everything up with the carbide bit what did you use to smooth it out with?
s383mmber1
3,614
Somers New York
Right now im smoothing it out by hand with a 200, then 500, and if need be, and 800!
Its very very smooth. VERY smooth.
TRACKMKIII
464
Atlanta,GA
Again wow man!! Sanding it by hand! Thumbs up! I am going to try the 80 grit sanding roll first and see how it turns out. One cool thing I did learn from one of the old guys at the shop is if you are using a carbide bit on something like these you should coat the bit in wax to keep it from picking metal shavings. It really works!!
NA86.5
NA-T Complete Yo
Jan 20, 2006
459
Alice Tx
Damn guys those parts look awesome I need to buy me a dremel and bits. I wanted to ask you guys after you guys polish the parts will they tarnish after time? Iam just wondering because I want to start polishing my stuff also.
TRACKMKIII
464
Atlanta,GA
I haven't had my first set on for very long so I am not sure if it will tarnish yet. I thought about spraying the out side with a clear coat to make it easier to clean though. If you are thinking about doing yours soon here some links with some good information!
http://www.advanceautoparts.com/english/youcan/html/res/res20040801pm.html#
http://www.miracerros.com/mustang/port_intakes.htm
I hope it helps!!
DEFIANT 7M
101MM stroke of INSANITY!
Nashville/Miami
If anybody wants to take this to the next level. Adapt a N/A 2J intake to fit. The design is the exact same as a 7M just a lot bigger. I've mentioned this before:icon_bigg
89Joe
POTATOES!!!!!!!!!!!!!!!!!
Jul 22, 2005
300
Missouri
Wouldn't this require porting the head to match the ports on the mani? I plan to do this yet I'm confused about making the diameter of the induction ports larger in comparison to the ports on the head. I need this cleared up because I don't know how to go about this at the moment:1zhelp: . Then again...I'm not sure if I said this right...jeeze I'm a nub...
TRACKMKIII
464
Atlanta,GA
What do you have to do to adapt it? Will you still use the 7m throttle body? Will the ACIS still work the same? This would be sweeeet!!!
TRACKMKIII
464
Atlanta,GA
Sl1dewaysSupra said:
What kind of gains have you seen w/ those ported? Or have you not put them back on?
I haven't put this set on yet. I recently did anothor set but I did not remove nearly as much material as this time. Hopefully I will have them done in the next week and I will let you know how it turns out!!
8,898
If money is growing on trees, you can always pick up a manifold on and Y pipe on ebay, and ship it to extrude hone. They are expensive, but it is very effective.
TRACKMKIII
464
Atlanta,GA
IJ. said:
Seeing it's on an NA it'd be interesting having a before and after flow bench tests!
I have been thinking the samething the whoe time I have been working on this project but I have no idea who even has a flow bench in my area!!
