polished stock ct-26 housing
selfinfliction
434
ky
i figured since the valve covers looked good after grinding off the ridges and polishing, i would do the same to the turbo. i ground off all the lettering on the turbo and polished it too. this turned out very nice imho
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
I like the Toyota CT26. It makes people think it's stock... They can't see the 62-1 wheel inside :biglaugh:
selfinfliction
434
ky
AF1JZ;899071 said:
Damn, that looks pretty good!!!
ty.. next on the list is the factory heat shield, it's made from crappy potmetal with alot of impurities, but i'll give it a shot anyways :biglaugh:
selfinfliction
434
ky
TooGoode;899457 said:
what did you use to polish it with?
6" 3m radial 50 grit (green) disk -- these are actually made for jewelers, but work amazing on any type of soft metal, then 220 silicon carbide sandpaper on an orbital to smooth everything out, then the 3m disk again, then dremel everything out with a 180 grit abrassive disk, hand polish with 400-800-1000then polish with bench buffer and hard metal compound, then soft metal compound, then stick it in the parts washer to get off all the shavings and polish it with a white rouge and viola... mirror finish
<edit> sometimes i use wenol to do the final polish, but this new white rouge i got friday, does a better job
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
i done 2 of thosu befor but i removed the lumps on ti so it nice shiney and smooth plsu ti doe snto look stock at all
