I was enjoying a nice drive to work when i noticed my oil pressure was below normal. so i put some oil in and drive off to work again. 2 blocks from the auto part store the car begins to buck and starts to smoke. Like a chimney. i pull over check to see if theres pressure in the coolant system and theres none. i towed it home, checked again for coolant leaks or bhg. theres none. i pulled off the intake tube to the turbo assembly and had massive shaft play. i replaced the turbo assembly and it ran great for 20min. the newer turbo had virtually no shaft play, which gave me the idea that the seals were still good. i gave it one good rev and oil begins to spray out of the oil dip tube. i'm thinking massive blow by. compression test reads
cyl 1 ~ 120psi
cyl 2 ~ 180psi
cyl 3 ~ 153psi
cyl 4 ~ 150psi
cyl 5 ~ 120psi
cyl 6 ~ 180psi
should i start pricing rings?
cyl 1 ~ 120psi
cyl 2 ~ 180psi
cyl 3 ~ 153psi
cyl 4 ~ 150psi
cyl 5 ~ 120psi
cyl 6 ~ 180psi
