please explain what is going on!!!
chefma70
404
Florida
my engine starts but wont rev at all.:: angry ::
i have to give the engine gas if i dont the motor shuts its self off.:1zhelp:
the only two codes im getting are codes 32 and 51.:confused:
im so clueless right now.please tell me what is going on!!?!?:1zhelp:
btw i have a 7mgte!
radiod
1,342
Abbotsford, BC
Be a little bit more specific. How does it die? Does it sound like it floods itself? Does it idle rough on start?
Try diagnosing from the TSRM. Here's a link with a list of all the engine codes, I've pasted the two you've pulled as well.
http://www.cygnusx1.net/Supra/TechTips/engine_error_codes.aspx
Code 32
Diagnosis(Air Flow Meter Signal(7M-GE))
Open circuit in E2 or short circuit between VC and VS.
Trouble Area
Air flow meter circuit
Air flow meter
ECU
Code 51
Diagnosis
No "IDL" signal, "NSW" signal or "A/C" signal to ECU, during diagnosis check.
Trouble Area
A/C switch circuit
A/C switch
A/C amplifier
Throttle position sensor circuit
ECU
Have you troubleshooted your AFM and TPS yet? Inspect the wire and connections, play with it a bit, see if it improves. Do all the diagnostic tests that you can with your AFM/TPS, make sure they are giving you the right resistances in the right areas.
89nasupra
Sugar, Water, Purple
Apr 8, 2008
501
Lafayette, Louisiana, United States
jetjock;1514261 said:
He doesn't have an AFM code...
really??...... code 32..........
32 Air Flow Meter Signal(7M-GE)
HAC Sensor Signal(7M-GTE)
Trouble Area
Air flow meter
ECU
Diagnosis(HAC Sensor Signal(7M-GTE))
Open circuit or short circuit in HAC sensor signal.
Trouble Area
ECU
