Pitting on the lifters(cam followers)??
eraezer
851
9
Stockholm, Sweden
That's a shim and it's easy to replace since you already have it out.
Since to lobes on the cam will go against it there is a possibility that the cam gets damaged.
What does the cam lobe look like?
radiod
1,342
Abbotsford, BC
They should just pop out. No special instructions in the TSRM other than "remove". Here's the page for cam wear specs:
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?S=EM&P=48
I know that the cams have a tendancy to come out looking pretty nasty on the 7M but still work fine. I can't tell you a definite one way or the other on your's in specific though. Start by measuring and making sure they're within spec first.
