Alright im test fittting my rings in my bore to check the end gaps and have found them to big...
Just so you know im using my piston to push the ring squarely into the bore..
spec in my haynes is .0114-.0173 inch..top ring
.098-.0209 bottom ring
Both rings are .028ish i am running std size npr rings..
Will it be ok to run like this or will i lose compression?????
Thanks for the feed back DW:1zhelp:
