permatex red strong enough for flywheel bolts?
sparkplug619
2 Supras, 1 Paycheck =[
Sep 28, 2008
285
San Diego California
ok I went online and searched every place I can think of for some loctite 262 but nowhere, I searched every autozone in san diego, nowhere.
I found some "permatex high strength threadlocker RED" but I dunno if this would be strong enough, anyone have any input? personal experiences?
The funny thing is this stuff is all over the place and I was referred to this over and over again.
I really dont want my flywheel bolts backing out so let me know if I need to extend my search
sparkplug619
Sep 28, 2008
285
Poodles;1423628 said:
Same difference, just a different brand. It's fine.
thanks alot, just installed my flywheel a few minutes ago!
one more question, I am missing 1 single pressure plate bolt, is there anything unique about these bolts? or can I go down to a hardware store and match it?
gaboonviper85
3,236
Northeast Philly
Hardware store is fine but I'd replace every single one if that was the case....that way they are all the same and all the same weight....make sure to get grade8 bolts though!
sparkplug619
Sep 28, 2008
285
I know, I definitely would but time is a big issue. I will more then likely pull my tranny back out next month so I can upgrade the clutch and flywheel anyway
sparkplug619
Sep 28, 2008
285
ok I just went and bought 6 bolts from my local hardware store. they measured the bolts and told me they are 5/16, grade 8, and 1 1/2. I bought 6 and they dont fit. they screw in a tiny bit but it gets too hard, I dont wanna force em in though
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
using the correct torque sequence with new bolts, chased/cleaned female threads and oil lubricant, threadlocker is unnecessary. as for the pressure plate bolts, use the highest grade you can find ( 8.8 or 10.9)
Supracentral
12
Supra's are metric... You won't find a single SAE bolt on a Supra. Your hardware store guys are idiots.
sparkplug619
Sep 28, 2008
285
adampecush;1424375 said:
metric bolts! it scares me that you didn't know this...
Wow I shoulda known that.. I cant remember ever taking of an sae bolt:nono:.
I work graveyard from 3 till 7 and ive been up ever since so Its hard to think clear
