part of intake blocked off?
RiddledTomcat
22
Elk Grove
so im almost done with my swap, and i was curious to see if this would do any harm. the part circled in red is capped off. on both the pipe and the intake so theres no connection. ive been readin up and i guess thats where the air bypass valve goes. not sure. is it ok to leave it capped?
And then theres the pipe under the intake with all the vacuum mess that i guess also gets to that point through the smaller pipe in front of 3000 pipe. what should i do?
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Is this your engine?
That's where your BPV, or bypass valve goes.
Unless you have an aftermarket blow off valve on the upper hardpipe, it is hardly advisable to drive it as-is.
Even if you have an aftermarket BOV, you should run it as bypass and route it into the intake hose
Late
125
Appleton, WI
are you sure that is the hose that is blocked off? i know i have one blocked off on my intake but its the one behind that
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
yours is blocked off because that's where the stock BPV goes, and you have a dump to atmosphere blow off valve
RiddledTomcat
22
Elk Grove
oh crap your right. its the one behind it. the same one that is blocked off in Late's picture.
RiddledTomcat
22
Elk Grove
but i dont have any BOV at all
at least not that i know of
also that is not a picture of my engine, just one i found off of google.
