Godspeed;1139990 said:
sounds like fun... lmk how your dash turns out.
Im going to post up pics after i have it done with the steps it went thru. No work in progress pix, and have something that looks like crap for any length of time. After its a finished product, i'll post it all up. But basically I want to move around the Speedo, and tach with new 5" ones, then im going to put my boost gauge between them, and the turn signals above them. Then on the right side is going to be Coolant temp, oil temp, and oil pressure, with AF and voltage in the pillar pod, and Once I get my MAFT pro, im going to have the display unit mounted in the dash where the Fuel and boost gauges are now. Then my fuel level gauge is going to get mounted under that. The stereo is planned to be about where the climate controls are now, and then below that im going to install the turbo timer, FCD, and a few other odds and ends. Toggle switches for my fans, and so forth. Behind the glove box im probably going to install a bottle and have it run out behind the fender. I want to keep a stockish look to the car, and want to keep the intercooler pipes in their stock routing (just upgrade for hard pipes and BOV) Then im going to have the nitrous solonoid and fuel solonoid on a bracket under the fender so they can be injected into the intercooler pipes there before anyone can see that its there. So by the time someone knows what I have its already to late. LOL Im still doing my research on the nitrous system i am going to run though. I want it to have a safe mounting point on the firewall for the bottle, and keep it out of sight from anyone that doesnt know exactly where to look. And that in tune with the big lipp boss turbo should be a pretty potent setup. Hopefully. LOL
