ok so i just got my car back from the shop after a long 6 months i had it rebuilt cometic hg arps 3 angle valve job new valve stem seals. new water pump and thermostat no egr valve 1 14 in. electric fan and the 2 small ac fans running also. has a ct26 60 trim running only 5psi stg 2 clutch, all new fluids..
heres the problem i went out crusing tonight for about an hr after 30 mins. the carstarts to get hotter than usual so i pull off and stop let it cool down and the shut it off. after about 30 min i go to leave tried to start the car and it started sputtered and died... so i check the ic pipes to see if i have one loose... no loose pipes tried it again same result after 2 more tries with the same result i finally started it and gave it some gas and drove it away its missing a little but stayed running. and i drove home...
earlier today i was driving along and had to downshift to climb a hill when i noticed my car started to get a little hotter.. but cooled back down but when i went up a steep driveway that was about 200 yrds long it had gotten so hot it was boiling over.... the car doesnt smoke or leak anything and seems to have steady power. does anyone have any ideas as to what this could be from??? :3d_frown:
