overboost
dwall
20
jacksonville
i have a 1987 supra turbo. and it over boosts at 3500 rpm and jumps from 10psi to 15psi then hits fuel cut. it is not running an aftermarket boost controller or any other engine mods besides it bored.020. i found it had a stuck wastegate but it was stuck open :aigo:. so how was it overboosting with a stuck open wastegate. i will drive it again tomorrow and see if that fixed it but. i guess my main question is how was i overboosting with a stuck open wastegate.
Dan
Supracentral
11
If it wasn't stuck all the way open, you can still overboost.
Supracentral
11
ForcedTorque;1805073 said:
If you have no mods how are you even getting 10 pounds?
I've seen a few that could squeak out 10psi with no mods before hitting fuel cut. With a Lexus and S-AFC, I've seen them hit over 20 on stock fuel (but not for long before either the motor melted down or the turbo blew apart).
dwall
20
jacksonville
im sorry it has a fmic, lexus afm, k&n cone, and its bored but that's it. it might be a shitty boost gauge. the gauge came with the car. but the stock 1 says 8 and the other 1 says it goes from 10 to 15. and yes its the stock ct26
Dan
Supracentral
11
nofx230;1805275 said:
but your still running stock turbo elbow and down pipe???
Modded elbow and DP will give you quicker spool and will support higher flow, but the stock stuff is capable of way more than 10 psi.
Supracentral
11
IndigoMKII
2,181
Madison, Virginia
dwall;1805429 said:
Still stock injectors, how would I check to see if my wastegate is shimed?
So lets see.. a lot of boost on lex afm and stock injectors. I'd start saving your money because at this rate something WILL let loose inside the engine and/or turbo.
Try to pull on your wastegate with your hand and see if it even moves. The bracket holding the wastegate will sit flush against the compressor housing.
ForcedTorque
Join the 92 Owners Group
6,099
Get a stock AFM on there until you have the upgraded injectors to match the added air flow. BTW, look at your injectors as best as you can, and tell us what colors you see.
And when messing with the wastegate, pay some attention to the rubber boot on the back side. It might be hard to get to in the car, but you could take the two bolts out of it, so it hangs down a bit. This is what you are looking for. Notice I am pulling out on it to expand it. If not expanded, you would never see this hole. BTW, there are actually 2 holes in this picture.
