Over Drive lamp blinking and speedmeeter is dead!
Pyrorox
15
Sweden
Hi all im new here and i just bught my first supra so i don,t know what engine i got or anything but i got a problem when me and my friend was driving att high speed my over drive lamp started blinking and my speedmeeter died and crouis control died does annyone know what the problem can be??
americanjebus
Mr. Evergreen
wa.
Well are you 5spd or auto. I had the exact same issue and thought it was just one of the two pieces. But theres actually a 90 degree fitting coming off of the auto tranny connecting to 1st section of the speedometer cable.
Go under the car and disconnect the cable from underneath there should be a little metal tip sticking out you can hook up to a drill. If your speedometer works, top section is fine. then work your way down to next section. If both work, as in my case its the 90 degree bend coming off of the tranny.
~$120 for that 90 bend.
As a side note if anyone finds this thread in the future, I'll explain why it's causing the issues.
No speedo = no signal from the speed sensor behind the dash. Auto tranny and cruise control both depend on that for proper function. On a side note, if you're brake fluid is low and the e-brake light comes on, it won't allow the cruise control to work either.
PROJECT N00b
XBL: Mkiii DriFt3r
May 22, 2005
1,660
honolulu, california
alrighty! sorry to bring up this old thread, but my OD light is blinking and the speedo works. so if it still iss that cable ill chgeck it tomorrow. Also, is it bad to drive with that light blinking?
Thanks!
big thank you to AJ and Byron!
