other models/makes that utilize 25mm shim&bucket systems?
Cyrus
229
Bay Area, CA
I know about the Honda CBR, but unfortunately, haven't found any of those in the local pick n pull. the pick n pull also has no supras.
my question is, what other vehicles have 25mm shims between 2.5-3.0mm? i want to go vulture a shitload of shims so I can start a nice little collection, not to mention finish my valve adjustment. There are like 3 or 4 pick n pull's within a short drive from me, so if I can find a fairly common vehicle with these shims, I'm sure I can get a good harvest.
thanks!
Cyrus
229
Bay Area, CA
heh well after searching this forum didnt turn up, i searched *another forum* that shall remain nameless.. ;)
rather than deleting this thread, i'm just gonna post that info in here in the hopes that it will someday help some other soul who only thinks to search this forum.
7M valve shim donors
If you ever struggle to find cheap or variety of shim thicknesses a little searching turns up some places you can look for shims. Most valuable is the fact that honda has shims thinner and thicker than toyota offers.
* Some common compatible valve shim donors: 16-valve 4A-G(Z)(E)
* 4A-F(E)
* 7A-FE
* 7M-G(T)E
* 3S-G(T)E
* 5S-FE (pre-'93)
SOB shims
25mm diameter Used in Honda ('79--'83 4-cylinder CB750, 900, 1000, and 1100 series engines,
and 1050 CBX 6-cylinder engines, and others), Yamaha (V-Max, and the FJ1100/1200 series),
Triumph 3- and 4-cylinder liquid-cooled motorcycle engines, and older Toyota car engines.
HotCams makes shim kits but i found they dont carry the larg sizes. Honda dealer local to me had all but 1 shim i needed and all were like aprox $5 each as compared to toyota pricing of $8+ (canadian) im not sure what the toyota shims are but i remember people saying they are arround 10 bux each.
So simply raid your local pick a part for your normal range of shims and order any thicker ones you might need.
Thickness, Honda Part No. Toyota Part No. *
mm (inches)
2.30 (.0905) 14901-422-000 # n/a
2.35 (.0925) 14903-422-000 # n/a
2.40 (.0945) 14905-422-000 # n/a
2.45 (.0964) 14907-422-000 # n/a
2.50 (.0984) 14909-422-000 13753-74010
2.55 (.1004) 14911-422-000 13753-74030
2.60 (.1024) 14913-422-000 13753-74050
2.65 (.1043) 14915-422-000 13753-74070
2.70 (.1063) 14917-422-000 13753-74090
2.75 (.1083) 14919-422-000 13753-74110
2.80 (.1102) 14921-422-000 13753-74130
2.85 (.1122) 14923-422-000 13753-74150
2.90 (.1142) 14925-422-000 13753-74170
2.95 (.1161) 14927-422-000 13753-74190
3.00 (.1181) 14929-422-000 13753-74210
3.05 (.1201) 14931-422-000 13753-74230
3.10 (.1220) 14933-422-000 13753-74250
3.15 (.1240) 14935-422-000 13753-74270
3.20 (.1260) 14937-422-000 13753-74290
3.25 (.1280) 14939-422-000 13753-74310
3.30 (.1299) 14941-422-000 13753-74330
3.35 (.1319) 14943-422-000 # n/a
3.40 (.1338) 14945-422-000 # n/a
3.45 (.1358) 14947-422-000 # n/a
3.50 (.1378) 14949-422-000 # n/a
im gonna be doing a search shortly to make a list of vehicles and model years with the above engines. ill post that here as well.
jonahs_supra;1841424 said:
IIRC a mod to do with the 3sgte is to use the newer mr2 shimless buckets(1zz)
but only problem is they come in 5.06-5.74mm
so milling would be needed
3sgte had a common issue with slinging shims at high rpm and when installing bigger cams
http://www.mr2forum.org/forum/index.php?/topic/13-shimless-bucket-conversion/
Iirc that's because you measure from the inside of the bucket where it touches the valve to the top of the valve shim.
Even has the math in the link you posted And to do it it's about 300+$ iirc.
If your not revving crazy high it's not nesseccary tho it will drop some weight in the valve train.
1SZ-FE 1000cc Echo
13751-23030 5.12
13751-23040 5.14
13751-23050 5.16
13751-23060 5.18
13751-23070 5.20
13751-23080 5.22
13751-23090 5.24
13751-23100 5.26
13751-23110 5.28
13751-23120 5.30
13751-23130 5.32
13751-23140 5.34
13751-23150 5.36
13751-23160 5.38
13751-23170 5.40
13751-23180 5.42
13751-23190 5.44
13751-23200 5.46
13751-23210 5.48
13751-23220 5.50
13751-23230 5.52
13751-23240 5.54
13751-23250 5.56
13751-23260 5.58
13751-23270 5.60
13751-23280 5.62
13751-23290 5.64
13751-23300 5.66
13751-23310 5.68
Dyzzyman
57
Arizona
Try Bob's Used Motorcycle Parts
1325 East Elwood Street Phoenix, AZ 85040
(602) 437-3148
16th street and Salt River. I haven't gone in a few months, they're open Tuesday thru Saturday.
KTM530
154
santa rosa
cyrus, i was at the pic n pull in windsor last week and they have 3 mk3's freshley sitting.
not sure if thats too far north for ya.
Cyrus
229
Bay Area, CA
KTM, the trip would cost me about $40 round trip (gas and bridge tolls), whereas buying new shims would cost $50. still, it would be nice to start a little stockpile of shims for future purposes. I will think about heading up and doing a little harvesting. thanks for the tip!
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
78
Atlanta
I hate you CA people.
You get MkIII's dropped into your junk yards more often than Lindsey Lohan winds up in rehab.
Here in GA, it never happens. In fact, I believe that a Supra appearing in a Georgia pick & pull lot is listed as one of the signs of the Apocalypse...
KTM530
154
santa rosa
hate? pretty stong word to be used lightley, hiltler hated jews, i hate terrorest, you hate me because i have easy acess to vehicles? well to each his own.
