Ordering rims. Need Tires.
Hey guys I'm ordering some Enkei RPF1's that are 17x8 but I now need to decide on whats the best fit for tires on these rims. I'm not going for the stretched tire look. Would 245/35/R17 work okay on these rims?
Anybody else out there running 17x8's with on their mkiii? Most of the one I see are 18s.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
a 35 series tire???? why?
if your going to a 17'' rim then a 40 would be the correct, but i ran a 45 and it was the same...
i had 17''s and i didnt like them, for the ride sacrafice i couldnt stand it, so i sold the rims and tires and went back to stock blades as they were only 3lbs heaver each than the 5-zigen setup i was running. and a 235/245 tire would look good. more so the 235.
and why not go something larger in the rear? 8.5, 9, 9.5...?
werewolves182
is without a supra :(
Aug 23, 2005
436
Crownsville, MD
Id go with 245/40/17 for 17x8" wheels. I had 245's on my oil supra with 17x8"s and the tires were perfectly flush. Great fit and no bulge but no stretching.
Thanks guys for the input.
You said 40 would be correct? Okay thanks. I assume your saying that is correct with the 245 width right?
I'm keeping the tires the same right now because the deal I am getting is any 4 tires the SAME size and brand for 40% off.
Also I would go with wider in the rear but when it comes down to rotating them that might not work out to well. Plus Im N/A so its not like traction is a problem right now.
Maybe after my swap wider would be needed but not right now.
