Open slip and I'm still making two tires marks?
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
Texas Motor Speedway
Hey guys, I'm in a dilemma here. I checked out Jeff Langes suggestion of looking in the door jam, where it shows the tranny, then the numbers, and it ends with a 4, which meant open slip. :nono: But, if so, here is something I'm puzzled about, when I did my good burnout a couple weeks ago, I left two tires marks, both were pretty damn even too. Here are some pics to prove it:
What is the explanation for this? :aigo:
-Matt
1TuffSupra
Sho' Nuff
500
Raleigh, North Carolina, United States
Yeah someone must have swapped the diff on the car. Did it leave equal tire marks multiple times? If it did that must be the case. But a definite way you can tell that the car has a lsd is to jack the rear end up and spin one of the wheels, transmission in nuetral of course, if the other drive wheel spins in the same direction as the one your spinning you have a lsd. Cars with an open diff will spin the other drive wheel in the opposite direction
Or a Torsen! ;)
Suprastic
727
Manitoba
My 87 NA auto light up both tires evenly. It also digs into concrete and ashphalt to the same depth. The deepest I went was 2.5 inces in. I dunno, it happens everytime I do a brake stand. I should get pics of it sometime, or even a video.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
as long as you have the car jacked up to spin the wheels, wouldnt it be just as easy to slide under and check the sticker? look on the center rear of the diff to see the sticker, right in front of the jacking point. thats where i found mine
slow yota
I Wish I Had Lag
Jan 30, 2006
27
South Bend,In.
-Matt
I have ask..This ia an N/A supra??..and do you have auto or manual?..I can barley get my tires to chirp w/o power braking.:icon_surp
