one quick question
koreyd
172
fall river mass
are all the keys the same on an 87 supra. i have lost my key and have the trunk lock out of the car. can i get a key made fr the trunk that will unlock the steering column
koreyd
172
fall river mass
thanks just making sure i had the key made from the trunk lock and it works. car wont start but at least i cnan unlock the steering wheel now.
PCguylovesSupra
Happy go lucky......
Jun 18, 2007
242
Southwest MI
My car came with a second key, that still started the car and unlocked it, however it did not unlock the glove box. It is a valet key. So if it doesn't lock or unlock the glove box, then you know what you have.
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Same thing for me.
koreyd
172
fall river mass
i already have had a key. no just trying to get it to start anybody have a pic of the fusible link between the battery and the fusebox
koreyd
172
fall river mass
well i found that the fusible link had been cut and run to the battery. i think that the ecu is dead. trying to find one to test now.
koreyd
172
fall river mass
i have figured out why my ecu doesn't work. there is a burnt out circuit on it. and it must be the ground for the m-rel and the turn on for the ecu.
i am really glad a buddy of mine is an eletrical engineer and can fix it for me. hopefully tommorow she lives
koreyd
172
fall river mass
will the car start without a noise filter in it at all. can i just run the noise filter wires together and bypass it. or would that still cause my code 14
and the ecu i was going to have repaired is junk the copper strands have pulled away from the board and my buddy says no go on fixing it. he said it would be a permanent fix.
kotu100- i am gonna own u for that ecu. thanks again. will keep everyone updated if she lives
