So I got an initial blown headgasket. How? I dont know. But it didnt overheat, so I went the lazy way. It already had an hks 2mm stopper on it, so I just lifted the head and swapped out the gaskets. Started it up, and instant ::bhg:: So I took the head off, stripped it down, had it pressure tested and machined, put it back on. Torqued it down to 90lbs with the grey arp lube in 4 passes (40,60,80,90). Put everything back together........................ instant ::bhg:: once again. Wierd thing is, the first time, all the coolant went from the radiator to the oil system. This time, it's mixed in both the radiator AND oil system. WTF. So I did a compression test and here were the results #1-140 #2-130 #3-120 #4-120 #5-120 #6-120.
Can someone tell me what the f*** is going on please?
