There's several options, but it's mostly:
- Pick a shock
- Pick a threaded sleeve kit
- Pick a spring
- Pick a pillowball mount
Shock wise, the easiest one here is probably the off the shelf bilsteins because of their removable spring seat.
Threaded sleeves:
http://www.summitracing.com/search/...e/bilstein-coil-over-sleeve-kits?autoview=SKU
http://www.allstarperformance.com/product.htm?prod=872
Spring depends on the setup you use, but this is the cheap part of the build IMHO as you're using a "coilover" style spring which are pretty standardized.
Pillowball mounts are up to you, but you wouldn't want to run a silly rubber mount now would you?
You can also go the route of using bilstein's racing series that are rebuildable and have a threaded body already.  More involved, but better quality if setup by someone that's good at this:
http://www.speedwaymotors.com/Bilst...ock-7-Inch-Stroke-Comp-Rebound-3-7,39775.html
Keep in mind I have no idea which parts in those links will work.  I myself have a factory bilstein coilover setup on the front of my car.  Downside to coilovers like this is that you can't adjust ride height independantly of spring preload like you can a coilover like Tein.
Tein's are also revalvable, and they offer different spring rate and length of rod, etc.
This all boils down to money.
