old school HKS goodies
RPSil13
464
Anaheim, CA
anyone have any info on all the stuff HKS used to make for the mk3, i know they made the and exhaust manifold, 3000 pipe, etc, but what else
thanks
Art
suprafreek
brisbane
I have seen a hks 2.2 litre stroker kit for the 1ggte engine it was called 2ggte i no of one floating round still in AUS not just that
so would assume they did one for 7m aswell but dont quote me on that lol
hks vpc (vein pressure converter/converts AFM to map sensor)for 7m and 1g engines
ive seen 7mgte metal head gaskets
1ggtte metal head gaskets(discontinued but)
also hks cast iron manifold for 1g engine as well
70% sure they did a cold air intake kit for it aswell
i am pretty sure i have seen more will update if i find them
hope it helps some
Cheers
projectsupra
旧車スープラ
West Palm Beach, FL
s235.photobucket.com
You're going to have to narrow it down some. HKS made many, many, more parts than that. Just imagine every mod possible for the 70 Supra and that's what was made, then double it. Specifically for the 1G alone there was a supercharger kit, OEM looking twin turbos, T3 frame turbo kits, T4 frame turbo kits, stroker, intercoolers, many multiple catbacks, downpipes, multiple BOV/recirculate kits, FCON, SLD, FCD, two VPC chips and harness, camshafts, and more. Not to mention the universal adapted parts, EVC, IPM, auto trans indicator, TEMS selector. The list of parts for the A70 is huge and I still find something I've never seen before every now and then.
One of my favorite items in my Sigma/HKS collection is my jacket.
RPSil13
464
Anaheim, CA
i meant hks stuff specifically for the mk3 platform,
some stuff from estrellainc's thread
HKS Headers- working on it/sellin stuff off.
HKS IC KIT (working w/ Sage1)
HKS VPC (working w/Sage1)
HKS VPC ROM 21200-SUP009B 91Turbo ; 550 Injectors
HKS VPC Harness
HKS VPC SMF Adapter
HKS VPC Pressure Sensor
HKS VPC Sensor Harness
HKS VPC Air Temperature Sensor
HKS VPC Air Temp Sensor Mount
HKS VPC intake Pipe
HKS PFC F-Con Harness TP-14 -harness for 89-92 grey plugged ecu's
HKS PFC F-CON ROM E105V(E Type With VPC, 6110 Pressure Sensor) (4201-T014)
HKS PFC F-CON Pressure Sensor
HKS PFC F-CON Pressure Sensor Harness
HKS GCC (Graphic Control Computer)
HKS EVC IV(gonna get from mk3brent-)
HKS Control Unit (Stepper motor) for EVC IV
HKS EVC Scramble Boost Control Trigger
HKS Tems controller
HKS SSQV BOV
HKS old skool Gauges
(stuff dreams are made of) you never know-
dust it off N show me.
HKS Cams
HkS Cam Gears
HKS Rods
HKS Pistons
HKS coil overs (does anyone in SM have these?)
HKS Turbo
# HKS Fuel Management
* HKS PFC F-CON Components
o GCC (Graphic Control Computer)
o PFC F-CON ROM (E Type, 6110 Pressure Sensor)
o PFC F-CON Harness
o PFC F-CON Pressure Sensor
o PFC F-CON Pressure Sensor Harness
* HKS VPC Components
o VPC ROM
o VPC Harness
o VPC SMF Adapter
o VPC Pressure Sensor
o VPC Sensor Harness
o VPC Air Temperature Sensor
o VPC Air Temp Sensor Mount
* HKS AFR (Air Fuel Ratio Regulator)
o Super AFR
o AFR Type D
o AFR Type L
* HKS VPC (Vein Pressure Converter - DISCONTINUED)
* HKS AIC (Additional Injector Controller)
o AIC III Si (Additional Injector Controller)
o AIC Injector Harness
* HKS PFC F-CON (Programmed Fuel Computer)
3000 pipe
etc...
8,900
85mm pistons, Auto trans upgrade, bolt on turbo upgrade, full turbo upgrade including manifold, intercooler, alphabet tuning, twin power ignition, exhaust for turbo and naturally aspirated, cams, and a few other things.
Now and then you will see things pop up on ebay.
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
FUCKING PIMP!!I want that jacket
blk92suprat
J Zizzle
Jul 6, 2008
456
USA
SD2JZA70;1170272 said:
Ill have to dig up that old catalog but along with the sequential twin turbo kit for the 7M was front and rear big brake kits, various turbo upgrades, clutches, suspension etc..
It's too bad HKS discontinued all these goodies for our cars....
Whats the date on the catalog you got?
pnutcar
1jz Asshole :)
Jan 25, 2006
299
St. Louis, MO
I used to have an HKS FCON on my blitz ecu, that was fun.
Also ran the original HKS EVC. Best boost controller out there. 3 buttons: Low, High, and a knob for change on the fly.
