So, I know generally that an oil thermostat redirects flow from a "bypass path" to the cooler path as it heats up.
Here's the question:
When the thermostat is closed off cold, is the oil cooler still under pressure? (Is it still connected at the cooler exit to the engine oil when the cooler path is blocked, or is the cooler path COMPLETELY cut off on both sides from the engine?)
It makes sense that it would still be connected on the exit side but I wanted to get someone else confirmation.
Reason I'm asking has to do with the feasibility of plumbing in an accusump or other secondary oil supply into the oil cooler circuit. (Would it still work when tstat is closed?)
