What's the trick to removing it?
northdakotakid New Member Feb 17, 2009 173 0 0 North Dakota Jan 19, 2013 #1 What's the trick to removing it?
S super51fan New Member Jul 28, 2010 497 0 0 Indianapolis Jan 19, 2013 #2 Spray with some WD40 or something similar. Tap with rubber mallet.
supraguy@aol Well-Known Member Dec 30, 2005 4,232 37 48 Atlanta Jan 19, 2013 #3 Yeah, shouldn't be too hard to remove. If you're still stuck after wd40, you can try heating the gear a bit with a propane torch.
northdakotakid New Member Feb 17, 2009 173 0 0 North Dakota Jan 19, 2013 #4 Finally got it. Thanks guys. All down to bare block now.
I IJ. Grumpy Old Man Mar 30, 2005 38,728 0 0 61 I come from a land down under Jan 19, 2013 #5 supraguy@aol;1907298 said: Yeah, shouldn't be too hard to remove. If you're still stuck after wd40, you can try heating the gear a bit with a propane torch. Click to expand... It's sintered metal I wouldn't heat it ....
I IJ. Grumpy Old Man Mar 30, 2005 38,728 0 0 61 I come from a land down under Jan 19, 2013 #7 Be really careful not to scratch or mark the spokes...
northdakotakid New Member Feb 17, 2009 173 0 0 North Dakota Jan 19, 2013 #8 That throws it out of balance or what?
I IJ. Grumpy Old Man Mar 30, 2005 38,728 0 0 61 I come from a land down under Jan 19, 2013 #9 Creates a stress riser and they fail.... Outer ring falls off the spokes, if it has any nicks in it replace it they're not expensive.
northdakotakid New Member Feb 17, 2009 173 0 0 North Dakota Jan 19, 2013 #10 Ill be sure to look it over carefully. Thanks IJ
I IJ. Grumpy Old Man Mar 30, 2005 38,728 0 0 61 I come from a land down under Jan 19, 2013 #11 Welcome! It's one of the many 7M gotyas Another is NEVER EVER over tighten the Cam Belt Tensioner as it warps #1 cylinder!
supraguy@aol Well-Known Member Dec 30, 2005 4,232 37 48 Atlanta Jan 20, 2013 #12 Another is Never start a land war in Asia!
