oil pressure
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
ok... so, i posted before about the jdm oil pressure sending unit on my car, i changed it out for the usdm one, but now my oil press. gauge reads + 120 psi at ALL times, even w/ the battery unplugged and the car off... :1zhelp:
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
dunno... it's kinda hard to get to... i'm feelin lazy, i just put the usdm one on and replaced my power steering pump... so it'll wait another day... my oil pan gasket's still leakin, so i'll get to it when i do that tomorrow, i'll post again prolly tomorrow night if/when i finish
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
updating this thread.... i pulled the gauge cluster cover off and wiggled the oil press. gauge needle, and tried turning on the car... the needle won't move... at all, at any position...? is there any way to test for a signal using a circuit tester?
IHI-RHC7
"The Boss"
Oregon
the oil pressure gauge is just a thermometer...
voltage comes straight from the gauge fuse, which is powered up from the ignition switch. The sender is a variable ground, so more pressure = less resistance. A shorted sender would allow heat to accumulate in the gauge, permanently deforming the spring...
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
so, assuming it's shorted, is there any way to prevent this from happening again?
edit: and are you saying the oil pressure sending unit is a ground? (the sensor)... if so i know why it shorted
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
i was doin it just for good measure, i'm tired of leaks.... trust me, lol
edit:didn't see they were tapered either :-/... at least i learned something from my stupidity :-/
Supracentral
10
Negative - not stupid. Just uninformed, and you learned something. That's smart!
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
hm... well, at least i figured out what the problem was too, lol... i remember seeing smoke coming from that area when i ran the car for short periods (a minute) hope i didn't fry anything else :-/
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
and i see the tsrm never fails, lol... i think i'll make it a general rule of thumb to check the tsrm before i do anything from now on... it can only make life esier
supra90turbo
shaeff is FTMFW!
32
MA, 01440
+1'd ya on that one.
You are the smartest man alive!
JK, seriously though, good thinking. It didnt' take long for us to sink that in your head did it? lol
