Oil pressure gauge help
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
So I wanted to put an aftermarket oil pressure Gauge in. Simple enough right? I used the sender that came with the gauge. It's an autometer carbon series. There is 3 tabs at the back of the gauge.
One says Gnd
one says S
and one says I
so I figure gnd is ground, I is power and S is the signal from the sender. So that's how I hooked it up. It didn't work. It actually went backwards??? Lol
so troubleshooting I hook it straight to my battery thinking maye there was somethig wrong with my power or ground. Nope nothing. I tried switching the I and S wires and then it goes to max with the car off and back down to zero wth car on
I tried hooking it up to my friend's car (he has defi gauges though) an same thing.
Is it just my wiring? Or my gauge is garbage?
kneedragger85
363
Boulder, CO
Kevin
Apr 20, 2009
865
right so i am hooking it up right. at first i hooked it up in the car but it didnt work.. so i tried directly to the battery using alligator clips but it reads either all the way max or all the way negative.. as i mentioned in the first post.
so is my gauga broken?? :(
