Need to replace oil pan... I was reading the TSRM, I notice that I need to remove brake lines, shocks and front suspension member before I can remove oil pan... Is there anyway of bypassing all that step and remove the brackets and the 22 bolts on the oil pan along with flange? Anyone have a faster approach or technique to remove oil pan? Note: backyard mechanic without lift.
Your assistance is much appreciated.
Thanks.
Thanks.
