oil pan gasket...
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
so now, along w/ all of the other problems, my oil pan gasket has sprung a leak... any advice? the gasket's never been removed... god just hates me, and all of the bolts are tight
brad92t
186
Lexington, KY
www.haxors.us
FIX IT!! PULL THE MOTOR OR DROP THE CROSSMEMBER THIS WEEKEND AND FIX IT
i didnt and i paid for it with rod knock. mine was leaking like it had a HOLE in the pan.. and i was too stupid about supras at the time to know better. now my engine is out and i am in the middle of a complete rebuild! then again what better an excuse for building up a supra motor than rod knock! :biglaugh:
anyway, there is in fact a gasket on there and it is in fact cork. i was told by curt from elmhurst toyota the same thing, that there is no p/n for the gasket and to use sealant... but sure enough i pulled my pan and there is a cork gasket on it.
i would use the best sealant you can find... cork sucks.
supranaut
Rock'n Death with Spikes
STL
Then someone used an aftermarket cork gaskets when they tore it apart before you bought it. Cork gaskets suck! It WILL eventually leak. Figgie is 100% correct..use something like Right Stuff.
figgie
Twin Cities, Minnesot-ah
no there isn't
see the link i posted?
that is right from the TOYOTA Service Repair manual, There is in fact NO CORK gasket, it is RTV sealant.
jetjock
creepy-ass cracka
9,439
Must be why they've been successfully used since the dawn of automobiles huh?
I've never had one leak and that includes the three I've put on 7Ms. It's a simple gasket, one that doesn't have to work very hard at being one. If it leaks it was put on wrong, over torqued, or the pan/block wasn't inspected. Same with the valve cover gaskets. It's wrong to blame a part for the shoddy workmanship done by those using it.
FIPG isn't inherently superior. It's simply a way to reduce manufacturing costs and improve efficiency. For example a robot can dispense FIPG far easier than it can handle a gasket.
brad92t
186
Lexington, KY
www.haxors.us
figgie said:
no there isn't
i'm not sure why you felt the need to drive this home. i never said i thought curt was wrong, and i never said there is a toyota part for this gasket. i clearly said cork sucks, use sealant in my post. all i said was that i had a cork gasket on my pan, which i did.. so it seems like you are calling me a liar here :)
look in some of the non-toyota gasket kits out there.. plenty of them come with oil pan gaskets. i never said they were good, i just said they exist and that one was on my car.
cheers
daledoe
KILL U
Nov 18, 2005
1,467
MAINE
I see what figgie is saying it dos sound like you are saying it has one stock!!!
MDCmotorsports
Indy 500
www.MDCmotorsports.com
All the "gaskets in a tube" that I have used for an oil pan have leaked.
The cork works great, its just it has to be torqued and torqued correctly or it WILL LEAK.
Any thing over 5 ft lbs is kililng a cork gasket.
brad92t
186
Lexington, KY
www.haxors.us
ok you're right
i should say.. there was a gasket on mine and it was cork and that probably was the reason it was leaking... and i will be replacing said gasket with Right Stuff as per recommendation of toyota parts guy
:icon_bigg
That's the problem, people over torque a cork gasket and it fails. The gasket is then blamed for the failure. As JJ said, cork gaskets have been used for years on various motors...they will work fine, if you install correctly ;)
I used Right Stuff on my pan...didn't have a cork gasket in the Toyota kit. Hasn't leaked at all and was easy to apply since it's in a aerosol container.
