oil in #6 spark plug...
lppro
LP Performance & off road
Apr 21, 2007
895
Sugar Hill, Georgia, United States
ok so i was just changeing out my plugs on my freshley rebuilt 7m (has many other issues) i thought it was just burning oil because its a new motor and the rings havent set yet... well heres what the #6 plug looked like:
all of that oil on my hand came from the plug... im thinking that the idiot that rebuilt my motor got in a hurry and forgot to make shure the piston rings werent lined up on the #6 piston... this sucks... is there a way to tell if in fact the rings are all lined up? maby its valve seals? but the head has been freshley rebuilt... btw theres 385 miles on the motor..
i also just went back out there and took a flash light and looked down into the spark blug hole.. all you can see is oil... so the whole cylinder is full of oil... perfect...
billspreston01
555
North Carolina
I had a #6 plug look the same once. I took it out and it was covered in oil. Put a new plug in and ran it for a few days. When I pulled it back out it was completely dry. No idea what happened. There was no oil between the valve covers.
lppro
Apr 21, 2007
895
omg i have no clue what happened... but i looked into the plug hole before i put the new plugs in.. and it was completley dry! wich makes no sence... but its fine with me.. lol i put the new plugs in and everything back togeather and WOW she has never ran this good.... this was freakin wierd...
skim1040
work in progress
I had a similar thing happen to me, it ended up being a faulty valve cover far back near the #6 plug, and as a result of the angle of the motor, the oil just pooled down in the galley near #6
New valve covers and gaskets fixed everything. Hope if anything this gives you and idea!
