Oil Drive-Shaft bearings
mecevans;1683592 said:
The ones i got from sipracing required no modification.
Exception to the rule. They're made slightly undersized so they can be sixed for your oil pump drive shaft.
mecevans
1,295
M-bay, cali
The SIP bearing fit with no modification. I have a cam bearing tool and i drove them in myself. Clearence was in spec. Check my build thread.
suprarich
Guest
Nov 9, 2005
2,187
ohio
That was a dura bond bearing set. They do fit most times without needing to size them. The OEM bearings come slightly over oversize and most times need to be sized. I have a pic of the tool I made in "members rides".
