mecevans;1683592 said:The ones i got from sipracing required no modification.
Poodles;1684048 said:Exception to the rule. They're made slightly undersized so they can be sixed for your oil pump drive shaft.
Yes, but I still had my machine shop put mine in because they had the right equipment and shaved them to fit exactly right.TweeT91109;1684301 said:So its still going to fit.
mecevans;1684379 said:The SIP bearing fit with no modification. I have a cam bearing tool and i drove them in myself. Clearence was in spec. Check my build thread.
