oil disappearing, help?
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
My oil is disappearing from god knows where. i have replaced the valve cover gaskets, drain plug (with new gasket), checked to see if my filter was tight, replaced the oil hose on the right valve cover (down to the crankcase), and can't see any obvious drips or leaks anywhere. it's not burning any oil, no blue smoke or smell. where could it be going?
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
if its disappearing real slow its pretty normal man
but if its like 1 qt a week THEN you have a problem
edit:: damn 1 qt every 3 weeks is pretty fast
are you on stock CT? if so check your oil return line from the turbo and on the block side
mine leaked 1 qt every month from there
Clip
Oct 16, 2005
2,738
9
Virginia
havent taken the timing cover off, but wouldnt it be dripping down onto the floor since its leaking that fast?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Your front subframe isn't grimed up is it? Maybe check your inlets on the exhaust manifold for oil? But then again, you'd see the smoke probably if that was the case... Rear main seal? look around your tranny. Did you check the spark plug galley when you replaced your valve cover gaskets? Look at you spark plugs and see if they have oil on them. Also, check around your fuel rail and bottom runner on the intake manifold for oil buildup.
Oct 11, 2005
3,821
25
Thousand Oaks, CA
If you park it overnight on a clean area does it leave any drips? If no, you must be burning it.
My cars went from 1qt/1000 miles to <0.5qt/5000 miles after I replaced the valve seals. The only time you would ever see smoke was briefly after a cold start when the car had sat for a few days.
Clip
Oct 16, 2005
2,738
9
Virginia
nick, ill watch the mileage closely. gotta change the oil this weekend.
Pi, no drips whatsoever. used to have a few until i switched the drain plug for a new one.
valve stem seals are bad on these engines, you have 4 of them for each cylinder that can leak LOL
when I took my head apart (about 150K miles on the engine) all that was left of the valve stems was the metal cover to them and the little spring...no actual seal material left...
Use quality Viton seals ;)
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Do you have the stock engine undercover in place? I've got a leak right now that I haven't had the time to fix yet. It leaks out of the timing belt cover, pools into the undertray, pours out of the tray at speed... so, I don't leak oil where I park, but when I start moving it runs out of the tray.
I do agree that valve stem seals are a possibility, but when mine were going I had smoke when starting cold... do you?
8,897
That is what I was thinking too. He is just burning it. A higher mileage car burns more than a lower milage car.
The guy starts burning a little oil and you all start calling out blown head gasket.
Clip
Oct 16, 2005
2,738
9
Virginia
cre, undercover is clean :(
nick, is it possible to burn that much oil without seeing/smelling it?
