So long story short I narrowed down my oil burning issue to valve seals, Im also only burning oil on one cylinder. #4 to be exact.
Compression on this cylinder is 175psi its adjacent cylinders are the same or there abouts. Leakdown for this cylinder is 5% leakage. Vacuum gauge diagnostic showed no valve guide related issue.
I just changed my valve stem seals on this one cylinder today and Im still burning oil, I will say not as bad as before but its still smoking none the less.
Did I miss anything, is there anything else I should look into? Did I perhaps install the seals incorrectly?
Help or Advice would be much appreciated.
Thanks
~JDMMA70
Thanks
~JDMMA70
