Offset question not covered yet
Supraholics
.928 RWHP & Climing!
Apr 1, 2006
1,577
PA
www.supraholics.com
I've been searching all morning. Couldn't find any info on my question.
I would like at least a 275 tire. It seems you can fit low offsets. I've seen a few pictures. Now here's this:
10" +22 offset wheel for the rear. It will probably stick out too much, BUT can it me machined 8mm to 10mm???
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Could have put this in the sticky.. any ways... depending on the wheel you can take some material away. Personally I wouldn't do it though.. and for fitting a 10" and a 275 you need a +35 or more offset
MKIIINA
Destroyer of Turbos
Plano, TX
if you were to roll your fenders maybe. I am running 18x9.5 +30 in the rear and it fits, barely. I'm with Borhor on this one, machining a rim = bad.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
Again, it really depends on the rim. However I dont think you are gonna be able to take enough off a 10" +20 to fit under the fenders.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
well...thats what I meant. What I meant to say "in his given set of parameters, that wheel will not fit that tire under the fender...not by machining at least"
that better?
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
that better?
Agreed. Machining the wheel is crazy sketchy. I mean.. 5 bolts holding up the car in such a small spot.. I wouldn't want to weaken that at all. It is not like it is hard to find a 10" wheel that can fit with a 275.
