Odd clutch problem
canadian
Newbie
May 16, 2006
366
Victoria BC
After having the tranny/engine out I have it back in now. I went to press in the clutch and it immediately sprung right to the floor and stayed there. Almost like something pulled on it after I stepped on it.
How can I fix this, and why did it do this?
TooGoode
rediculous DD
Mar 1, 2007
549
Chandler, Arizona
you dont have to bleed it....i had the same problem....i though, oh shit....i need a master cylinder.....just get down on your knees and with your hand, pull it in and out repeatedly....this happenes because its not circulating fluid for a period of time....just pull in and out for a couple of minutes and youll be back and running!!
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
So youre saying that if you take the clutch lines apart you dont have to bleed the system?.....ok
Next time you take your brake lines off dont bleed them and go drive.
canadian
Newbie
May 16, 2006
366
Victoria BC
DaSuprawolf said:
there is no need to separate any lines to remove the tranny.
so............ no bleeding
(if thats what he did)
What about the line from the resivoir to the slave cylinder on the tranny? I had to seperate that line...
gravity bleeding won't work very well, and the clutch system as I've messed with it has never had the pedal go to the floor like that from having air in it...
sounds a LOT more like the snap ring on the hub popping off...
Supraboostin
7m power
MIAMI
gravity bleeding works for me and my clutch pedal did go to the floor before bleeding it so i dunno
canadian
Newbie
May 16, 2006
366
Victoria BC
I'll bleed it first, if that doesn't work then that may be it.
pull your inspection plates on the tranny and look in there, if the clutch fork is resting on the pressure plate that's you're issue...
