od & tems questions
jdm-rhd
59
orbiting caprica
im a noob when it comes the mkiii, just purchased my first a few days ago.
was wondering how to tell if tems controller is working.
also, its auto (both my mkiv's are/were manual) and the od light just flickers all the time, regardless if you press the button.
how can i verify that it is working properly?
btw its an 88 7mgte
thanks in advance
JDMMA70
2,550
Houston
Switch between the modes and listen for the motors actuating. Depress the accelerator pedal to simulate a WOT situation and listen and watch that the TEMS goes into full firm mode. On a test drive above 40MPH you should hear the TEMS also go full firm when braking.
As far as your OD light flashing, is your speedometer working? If so I would check for codes from the transmission.
