As per title. This is really annoying me because I can't drive it or get it registered until it's fixed!
Current mods/Things that were fucked with right before the miss occured:
550s
Bosch 044 in-tank fuel pump
AFPR
Map ecu 2 (with timing control)
HKS replacement 3000 pipe
custom intake
turbo-back 3" exhaust (straight through, no cat)
Aftermarket IC + piping
Aftermarket rad (with e-fan and auto switch on and off) + hard pipes
+ assortment of gauges and in-cabin electrics
Car went to the shop to get some of the above mods done, plus a small service (oil filter, plugs, bleed cooling system and put in new Toyota Red).
Went to pick it up, got told it "runs great" except for this damn miss on kick down.
I then found out the lazy fker didn't bleed the cooling system properly!!!!! I didn't have the climate control in the car, and he was too lazy to put the screwdriver in behind the glovebox to open the heater tap! On top of that, they put in Nulon, and not the Toyota Red we supplied! :icon_evil:icon_evil:icon_evil
Now, I have the dreaded waterfall sound behind my dash!!!!!! :cry::cry::cry:
Now, we would like to try and get this sorted this weekend, and so far, these are the things we are going to do:
- bleed cooling system PROPERLY and add in Toyota Red
- check the plugs and leads
Is there anything else we should investigate/do?
Also, below are my dyno sheets... Don't know if these will indicate any issues or not though...
View attachment Dyno Sheet - AFR.pdf
View attachment Dyno Sheet - PSI.pdf
Any help or suggestions will be most appreciated!
550s
AFPR
custom intake
