OBX Underdrive crank pulley doesnt fit
figgie
Twin Cities, Minnesot-ah
bigaaron said:
:biglaugh: at least you can laugh about it :biglaugh:
PS: to hit the 12k redline you have to get it going about 70, put it in first, and let out the clutch!
<edit IJ> And duck ;)
lmao
not duck
pull your legs away from the clutch, throttle pedal area as shards of motor AND transmission come a wizzing in ;)
bigaaron
4,692
Pomona, CA
www.driftmotion.com
What's really funny is that I saw a brand new Honda S2000 with a supercharger at a dealership with a blown engine and the tech told me the OBDII had recorded a peak of over 14k RPM!
"He has to have 100K under the hood of that s2000" ;)
bigaaron
4,692
Pomona, CA
www.driftmotion.com
HellsLegion said:
There was an s2k with a supercharger and the dealer still worked on it? Was it an option or somthing?
He had a shop put it on and then he brought it into the dealer to "warranty" it after it exploded! Needless to say, he paid for his stupidity! LOL
I was just installing monitors in a new suv and I went over to talk to the tech about it.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
RIPDOTCOM said:
got it, just took a tiny bit off the pulley where the woodruff key goes and it fit like a champ, thanks for the votes of confidence.
umm no what happen when you put thosu dumb things on is you eninge will eat it's self over time there is reson why there is damper cause it freaking stright 6 it's a vibe wounder
alot fo the times the blancer will just fall off cause of the vids looseing the crank bolt so
but there si but if you have race motor that is built and preftly blance then you can run one but over time ti will just fall off cause engine go out fo blance whiht high mialage
any ways have fun hope i did not pee in your corn flakes
s383mmber1
3,614
Somers New York
(this is a joke, please do not try this at home)
I read half way through your post, ran out and tried it without reading the second half.
You, sir, owe me an engine. Possibly two.
ma70t
7mgte-s
Jun 7, 2005
141
va
there a s2k that runs 10's and stiill street legal its from inline pro but turbo tho everything stock except for the turbo system
for some reason in va md and dc there alot of s2k charged around here but never ran into one on the street
