Obx Headers
Status
Not open for further replies.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
92nsx;1055915 said:
Use the Search.
DO NOT POST THIS CRAP! If you don't know the answer then don't reply. If you do know the answer and want to advertise the search feature then post the answer along with the suggestion!
There are a couple guys running them including Cuel. Check the following threads for more info...
http://www.supramania.com/forums/showthread.php?t=71826&highlight=headers
http://www.supramania.com/forums/showthread.php?t=72976&highlight=headers
http://www.supramania.com/forums/showthread.php?t=66525&highlight=headers
http://www.supramania.com/forums/showthread.php?t=64495&highlight=headers
92nsx
2,957
Clearwater, MN
Supracentral said:
Dealing with the "oldschool" guys
(or: How to ask smart questions..)
Before asking a question do the following:[/B]
Try to find an answer by searching this website.
:evildeal: :asshole:
gofastgeorge
944
Texas
Personally, I would never use a header by a chinese firm that was copied from an existing established manufacture.
And if you do a search on Google, with terms like:
'OBX crap' or 'OBX junk', etc., you may not want to use that low-buck counterfeit stuff either.
Pacesetter is the original header that the obx junk was copied from.
zachm611
Beauty In Disguise
Apr 15, 2006
543
new mexico
my experiences with pacesetter on a different car werent that great. fitment was off and then after a month or so it started leaking, it rattles its rather irritating pulling into a parking lot and it will be rattling and hearing the exhaust leak going. just gotta save up for a real header. though i remember hearing the obx was better then pacesetter. i dont remember who said it.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
my obx i bought off here from another member. had to grind a little more off of the trop right, and he had already had them modified so it had the o2 bung in the one collector.
my biggest complain is that it goes from dual 2''(ish) collectors down to a single 2'' pipe... its a horrible bottle neck for the system, and getting them to seal was a bitch with the y-pipe, if i were to do it over again i would weld on that little y-pipe thing and then put a 2.5'' pipe off of the y-pipe and then plumb that back to the cat so its a nice big pipe.
i noticed top end more so than the low end, but it did get it more sound. and if you want to just PISS your neighbors off, start it up just straight open header, it sounds ungodly in person, i would run it like that on the streets if it wasnt for the fact i live in CA...
gofastgeorge
944
Texas
Never had any fitment problems with my Pacesetters.
But yes, the bottom collector looks to be an after thought.
(both brands, since the obx is just a copy).
I never used it.
I just built my own (2 smaller pipes dumping into a 3" collector).
Supracentral
10
This was the appropriate reply people.
If you're going to tell someone to search, do so, but help them as well.
Thread closed.
Status
