November Mini Meet
VanSupra
Van,B.C.
Well, due to popular demand and requests from our die hard Supra fans on the wet coast, Sunday Nov 19th/06 1:00PM Red Robin Guilford. I hope to be up and running by then aswell so, "Be there or beware"
:naughty:
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
xXxICExXx said:
What stage is it at?
Lets see here... I need to:
- check valve clearances
- install valve covers
- pull engine off stand
- install rear oil seal
- install oilpan
- install flywheel & clutch
- install tranny
- drop engine and tranny into car
- install driveshaft
- hook up power steering, AC, alternator
- tighten crank pulley
- install belts
- install radiator
- install radiator fans
- remove IC, clean, reinstall
- install IC piping
- install plug wires and coilpacks
- connect all wiring
- install MAFT Pro, including MAP sensor, wideband, IAT sensor, boost control solenoid
- install shifter
- reassemble dash
- charge battery
- install battery
- tune
- ENJOY :D
xXxICExXx
366
Abbotsford, BC, Canada
- install oilpan
- install tranny
- install belts
- install radiator
- install IC piping
- install shifter
- reassemble dash
- charge battery
- install battery
- tune
- ENJOY :D
Maybe you will make the january mini meet :icon_razz
BTZ
Burnaby
- install oilpan
- install tranny
- install belts
- install radiator
- install IC piping
- install shifter
- reassemble dash
- charge battery
- install battery
- tune
- ENJOY :D
lol, install 2 driveshafts, lol.
ill be there...
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
how you break damper ??? did yae just chip it or some thing
mine has chip in it i really shoudl replace it but i really thinking on getting one
oh yae if you don't have puller 2 flat blade screw driver and wiggly the shit out fo it if not use puller if that don't work i wan tot see you r car done secound time befor mine even run's
run's away crying
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
I have a puller.
There was a small dent in it, so I tried to tap that out with a hammer, and a sizeable chunk of the damn thing just popped off. :(
I'm concerned that if I left it like this, it would eat belts.
