Notorious leaks?
jessetooslow
551
Tiverton, R.I.
:1zhelp: Are the MK3 Supras known for leaking any fluids in certain areas, I noticed my car always has a wet spot under the motor, could it be a rear main seal, if you guys know of any leaks, let me know please, thanks
Kckazdude
1,239
Memphis, TN
Idealsupra said:
i have a constant leak out of my wallet
You too!! How bad is your leak? Mine seems to be really bad at payday.
On topic, I do need to replace my rack and pinion as it seems to be leaking now.
Ckanderson
2,644
The beach
targa seals.
youll know after it rains or you wash your car, and a huge stream of water pours either on your head, or in your lap.
mkIIIman089
Ohio
CPS (internal or external), cams, front main seal, PCV vent tube on side of block, oil pump drive seal, valve covers.
Those could all create what you're describing. For me it was the CPS internally.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Also, check to see that your PCV system isn't clogged, you want as much vac. on the crankcase as possible to help keep oil seals from blowing out.
